changing reaction rate
Old   December 1, 1999, 20:52
Default changing reaction rate
Arthur Valais
Hello All,
Does anyone have any source code snippet on how to alter the volume reaction rate on a per cell basis after each time step or iteration? My guess is to use DEFINE_ADJUST and DEFINE_VR_RATE together but I'm lost after that. Any clues will be appreciated.
Arthur Valais
Old   December 10, 1999, 10:53
Default Re: changing reaction rate
Joe Maruszewski
Here's a rather silly example of how you could modify the reaction rate as a function of time. In the example, when a new time step is done the reaction rate is cut in half.
#include "udf.h"
DEFINE_VR_RATE(my_rate, c, t, r, mw, yi, rr, rr_t) { static real old_flow_time = 0.; static real specified_rr = 1.; if (RP_Get_Real("flow-time") > old_flow_time)
specified_rr /= 2.; old_flow_time = RP_Get_Real("flow-time"); *rr = specified_rr; }
If you could be more specific about what you are trying to do I may be able to provide more suggestions.
Joe
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 16:55
UDF for catalyst volumetric reaction, temperature overshoot though rate is small elmcmaster FLUENT 0 October 11, 2010 09:37
surface reaction rate with udf yellow-stuff FLUENT 4 January 29, 2010 12:53
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 13:20
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
