gas/liquid outlet in circulating zone
Old   January 18, 2000, 03:03
Default gas/liquid outlet in circulating zone
Paal Chr.
Hi there,
I'm working with a gas/liquid, stirred tank reactor. I have given up using a free surface in the system, so I have to put the outlet close to where the surface is expected to be, but in the two-phase area. My problem is then how twp specify the outlet parameters. My guess is that I have to skip the outlet and use a sink term for the gas fraction instead. Does anyone have a better idea?
How can I link the gas fraction at the inlet to this sink term so I will be guarantied that the conservation equation will be fullfilled?
I hope someone can help me.
PC.
Old   January 21, 2000, 15:01
Default Re: gas/liquid outlet in circulating zone
S. Vasquez
HI,
You can probably do this problem as follows:
i) Use Adjust UDS and calculate the total mass of gas going into the system. ii) You can use symmetry (or link-cut walls) b.c for the liquid in the "modified outlet"
ii) Use this total gas in to adjust the velocities of the gas at the cells near the "special outlet". This can be done via urstrm.F (user defined subroutine for source terms in the equations) by setting a sink term for the velocities on that region. You may also be able to do via "adjust UDS."
iii) Use the urstrm.F subroutine to set a sink term for the volume of fraction equations.
iv) Contact your support engineer for more specific questions about variables in the UDS files.
v) Depending of the gas inlet velocity you may also be able to do this problem with Fluent5 (UNS)
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
VOF Outlet boundary condition in cfd - ace JM Main CFD Forum 0 December 15, 2006 08:07
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
Sliding mesh error Karl Kevala FLUENT 4 February 21, 2001 15:52
