Stirred tank with baffles simulation using single rotating reference frame |
March 4, 2000, 08:55 |
hi,
I want to know --Can I use single rotating reference frame to simulate stirred tank with baffles? In this method the tank wall and the baffles are defined counter rotating walls. Therefore I need not use multi-frame of reference. Can I do this? Please tell me. Thinks. M.zhou |
March 5, 2000, 15:01 |
Re: Stirred tank with baffles simulation using single rotating reference frame
I'm afraid you can't use a single rotating frame of reference. You should use either multiple rotating frames (MRF) or sliding mesh capability in FLUENT. The MRF is a convenient, much cheaper alternative to the full transient sliding mesh capability. Please refer to User's Guide.
rotating frame of reference and total pressure | viking | ANSYS | 1 | November 23, 2010 23:25 |
OpenFoam-1.7.x on Suse 11.2 (64bit) does not compile | val46 | OpenFOAM Installation | 4 | August 27, 2010 03:43 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Single reference frame model | srinivas | FLUENT | 0 | December 10, 2006 07:34 |
Windows Installation BugsComments on Petrbs patch | brooksmoses | OpenFOAM Installation | 48 | April 16, 2006 00:20 |
