May 4, 2000, 16:32 |
Cell Mass flux
In a 2d problem with quad cells, I want to be able to calculate what is the mass flux of fluid flowing across a particular edge of the 2d cell. Is there a way to get this value by UDF's or by anything ?
May 5, 2000, 04:11 |
Re: Cell Mass flux
Hi Sandeep,
the following UDF allows you to calculate the flux across any thread in a 2D domain. If you want to calculate it for a single edge of a 2D Cell, I would recommend creating it as an independent 1D INTERIOR boundary condition. Then you can apply the algorithm below. Perhaps a check for the nodal coordinates of the given cell would also allow for a modification of the function below (Jonas! Another one for the repository! /************************************************** ****************/ /* This function calculates the flux across the given boundary. */ /* We make use of Fluent Macros for this. */ /* Note that the THREAD_ID parameter is the integer value shown as ID by the Boundary Conditions... Menu. */ /* Also, you must have defined domain as a global variable: */ /* extern Domain *domain; */ /************************************************** ****************/ real flow_rate(int thread_id) { real flowrate = 0.0; face_t face; Thread *face_thread; face_thread = Lookup_Thread(domain,thread_id); begin_f_loop(face, face_thread) { flowrate = flowrate + F_FLUX(face, face_thread); } end_f_loop(face, face_thread) return flowrate; } Hope it helps! AL |
May 5, 2000, 08:51 |
Re: Cell Mass flux
I've added this UDF to the temporary UDF library at:
ftp://ftp.cfd-online.com/fluent/ I named the file "flux_calculation.c" As before anyone can contribute other UDF's by uploading them to: ftp://ftp.cfd-online.com/incoming/ |
May 5, 2000, 08:56 |
Re: Cell Mass flux
Thanks a lot AL.
mass flow boundary with fractional mass flux specifications | ehsan_am86 | CFX | 2 | May 19, 2011 03:02 |
flux around one specific cell | solefire | FLUENT | 0 | October 7, 2010 17:25 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
Creating 100 derived parts / Splitting derived parts for mass flux calculation | xamo | STAR-CCM+ | 8 | September 29, 2009 05:35 |
How are the mass flux and mass flow rate defined? | Miles | Siemens | 2 | November 7, 2002 08:45 |
