Unsteady computation using sliding mesh
Old   September 7, 2000, 07:03
Default Unsteady computation using sliding mesh
Ales Skotak
In solver Fluent 5.3 I am trying to use the multiple rotating frames of reference or the sliding mesh. In my rotor-draft tube interaction the back flow passes through the rotating-stationary interface. If I computed this task as a steady, no problem occurred, convergence facilities were good. When I switch on the unsteady computation, the solution start to diverge after five time steps. The behavior is independent on the time step size. This unsteady computation converged well in turbine operation point, where the back flow did not appear in the rotor-draft tube interface. Is there any solution or advice?
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
Using sliding mesh for unsteady turbomachinery problem happyman Main CFD Forum 3 July 8, 2011 14:29
Using sliding mesh for 3D unsteady turbomachinery problem happyman FLUENT 0 June 22, 2011 15:54
use sliding mesh to simulate unsteady flow annie FLUENT 3 November 9, 2004 07:48
