discrete phase convergence
Old   September 12, 2000, 04:57
Default discrete phase convergence
steve platt
I am modelling a tank where water flows in at the base and then flows through a porous region before leaving through an outlet close to the top. The top of the tank is a free surface which i am modelling as a slip wall. Air is also added which i am trying to model as a series of discrete phase inputs. The model converges fine in 2d but not in 3d, although it will converge without the discrete phase. Can anyone suggest something that i can try?
Old   September 12, 2000, 10:49
Default Re: discrete phase convergence
steve platt
I've just realised that i've missed a bit out. I have tried setting the slip wall (free surface) as an escape boundary for the discrete phase. It works and converges in 2d but not in 3d. Any help will be appreciated.
Old   September 13, 2000, 03:11
Rüdiger Schwarze
Do You want to get a stationary solution? I think the plume in a gas-stirred tank won't be stationary and You should try to get a transient solution.
Discrete Phase Model vittal FLUENT 4 October 28, 2014 10:07
Force can not converge colopolo CFX 13 October 4, 2011 22:03
continuous and discrete phase coupling in fluids-HELP atmcfd Main CFD Forum 1 December 30, 2009 23:02
questions about the discrete phase model lisa FLUENT 3 January 17, 2006 07:51
uncoupled discrete phase calculations AMV FLUENT 0 December 3, 2003 07:21
