September 14, 2000, 10:52 |
fluent 5 3d model
hi pple,
i am using fluent 5 to predict the pressure distribution of lubricant in a plain journal bearing. i have encountered reverse flow at the certain face located near the pressure inlet (boundary condition) .this occur when i initialise the solution and iterate it with four boundary conditions.(journal-wall,bearing-wall,pressure inlet and pressure outlet).this reverse flow might occur at pressure outlet.laminar flow. i am working with atmosphere pressure(101.3kpa) at the inlet(gauge).zero gauge at the outlet pressure.journal is rotating while bearing is stationery. pls give me some advice to solve this problem.thank you. |
September 14, 2012, 01:33 |
Dinesh
Rep Power: 16 |
I am also facing the same problem.
Seeking Macroscopic Particle Model in Fluent | bzhang7 | FLUENT | 3 | June 25, 2022 17:54 |
H ow to compute the model by FLUENT and ANSYS | njiit | FLUENT | 0 | March 2, 2010 22:24 |
Fluent 12 k-w SST turbulence model | DarrenC | FLUENT | 0 | December 13, 2009 08:33 |
Covert Star-CD model to FLUENT | Lam | Siemens | 6 | June 24, 2003 20:21 |
