Time step for rotating frame
Old   September 19, 2000, 02:02
Default Time step for rotating frame
Ales Skotak
In my turbine runner computation I used multiple rotating frames of reference. I used only one rotating blade segment and stationary bladeless parts upstream and downstream. Unsteady solution converged well. When I solved the task as an unsteady one with relatively large time step (1*number_of_blades*rotating_speed) and task again converged well. When I used the shorter time step (0.1*number_of_blades*rotating_speed) the solution could not converged. Is there any restriction for the critical shortest time step in the unsteady computation?
Old   October 28, 2000, 07:59
Default Re: Time step for rotating frame
Peter Staykov
Hi Ales, I have solved similar tasks with Multiple References Frame (MRF) and Sliding Mesh (SM) computational techniques for different type of turbines - Rushton, Pitch Blade and NS turbine - and I have solutions for these types of impellers with one and two turbine stirred tanks. In your question I do not understand what dimention do you use for rotating turbine, more precisly,
in your formula : 1*number_of_blades*rotating_speed
what is the dimention of the rotating speed - rpm, rps or Hz ?
Best regards, Peter Staykov
Old   November 1, 2000, 02:11
Ales Skotak
Hi Peter, Thanks for your comment. The formula for the critical time step is dt=1/(rotational_speed * number_of_blades). The rotational speed is in round per second. It does mean, that the critical time step value is the same as the blade passing frequency. When I use the lower time step then the blade passing frequency, I could not obtain converged solution.
Best Regards.
Velocity blows up suddenly after 30,000+ iterations lordvon OpenFOAM Running, Solving & CFD 15 October 19, 2015 13:52
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
Intermediate step during a time step Burn OpenFOAM 0 July 16, 2009 10:01
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
