Boundries of rotating impeller created in Gambit ?
Old   October 20, 2000, 08:39
Default Boundries of rotating impeller created in Gambit ?
Mounir
I am working on mixing in stirred tanks.
I have created the geometry in Gambit : impeller, tank, shaft and baffles. I plan to use Fluent 5 as a solver.
- How to make the impeller and shaft rotating? - what kind of boundries should be defined for the the rotating shaft and blades in the cases of the use of fixed boundry conditions, multi reference frame (or sliding mesh) ?
Best regards Mounir
Old   October 21, 2000, 13:45
Default Re: Boundries of rotating impeller created in Gamb
Harry
Hi mounir you've a project similar to me. i do the same thing, using pitch blade. first i've a trouble like you too, but now it's solved.
to make your impeller and shaft rotating with the same speed with your fluid , specify it as rotating wall relative rotation set to 0.
good luck
Old   October 23, 2000, 06:56
Jack Keays
Due to the presence of Baffles, I think it is likely you will need to model the problem using a sliding mesh. There is an example in the fluent hand book. Also, specify the shaft and blade as walls and then specify the speed of rotation of the fluid zone around the blade and shaft. Jack.
Gambit 2.3.16, Xming or Exceed...HELP! bambam3417 FLUENT 10 May 7, 2010 12:39
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
Dead cells created on edges when a grid file is generated in GAMBIT and imported into FLUENT4 Isaac Manohar Ch. FLUENT 1 June 2, 2000 04:58
