radiative heat transfer
Old   November 16, 2000, 09:47
Default radiative heat transfer
olivier
hello, I modelise coal burner in furnace. I have a coal flame and I would like to know the part of radiative and convective heat transfer on the load...
I need some help about. thnaks and bye
Old   November 17, 2000, 07:34
Default Re: radiative heat transfer
Angus Duncan
Hi Olivier,
Assuming that you are interested in the heat transfer to the furnace walls then you can simply report total and radiant heat to walls (Report >Fluxes). In a furnace, the bulk temp will be some 1500 degC reaching peaks of some 1800-1900 degC, therefore the majority (>70%) of heat release will be radiant.
Angus
Radiative Heat Transfer kamakura117 STAR-CCM+ 0 July 19, 2010 19:51
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
radiative heat transfer Tim FLUENT 0 February 20, 2004 13:28
