Can i get CL from fluent?
Old   March 19, 2001, 03:42
Default Can i get CL from fluent?
TC YAP
hello, can i get the lift coefficients (CL) from Fluent and how? thank
Old   March 19, 2001, 05:35
Default Re: Can i get CL from fluent?
David Smith
The coefficent lift is obtained via a force monitor solve > monitors > force
you must specify a file and for each iteration a lift (or drag or moment) will be outputed to the file. it is important to make sure the lift has converged - it may only look like it is changing a little bit between iterations but over several thousand iterations this will make a fair difference.
Dave
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
