Is this UDF correct?
Old   April 4, 2001, 03:36
Default Is this UDF correct?
JJ
Hi all,
I am a novice in C programming, I wrote the following in an attempt to generate a two layer flow in my domain. But when I try to compile it, fluent keeps giving me error msg. Not sure what is wrong. Can anybody help? Thanx.
#include "udf.h"
DEFINE_PROPERTY(cell_density, cell, threads) {
real density;
real grid_y = NODE_Y(c,t);
if (grid_y<0.81)
density = 998;
else
density = 968;
return density; }
Regards, JJ
Old   April 4, 2001, 04:27
Default Re: Is this UDF correct?
Greg Perkins
try grid_y = NODE_Y(cell,threads);
Old   April 6, 2001, 07:08
JJ
Hi Greg,
Thanx for your help, tried it and I was able to compile it. But I am still stuck cos when I try to initialize the flow, I obtain the following error msg "2ldensity.cpp:6: macro `NODE_Y' used with too many (2) args"
2ldensity is the name of the UDF. May I know what can be done?
Thanx in advance.
JJ
Old   April 8, 2001, 18:54
Greg Perkins
Actually you'd be better to use C_CENTROID to determine the location of the cell centroid. Check this out in the udf manual.
Greg
UDF and text commands David FLUENT 3 June 26, 2022 23:10
UDF to record FLUENT Solver variables... mariachi Fluent UDF and Scheme Programming 11 September 24, 2019 00:07
how can I correct the udf? happyrabbit FLUENT 9 January 28, 2011 09:50
UDF to record FLUENT solver variables... mariachi FLUENT 1 February 3, 2010 22:18
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
