Variable Names in Profiles
Old   April 18, 2001, 06:59
Default Variable Names in Profiles
Jonas Larsson
Just a little bit of advice if you use profiles...
I have just spent an hour trying to figure out why my inlet/outlet profiles in Fluent won't work as expected, and once again have I re-discovered that you can't use numbers (0-9) or upper-case in your profile variable-names. By default I tend to call total-temperature for "T0" and if you do this in Fluent (I tried it on HP and Linux platforms) your profiles will not work and you will not get a simple error message explaining why... *sigh* changing case and replacing "0" with "total" isn't the first thing you try.
Hopefully I'll remember this next time now ... (hint to Fluent: please fix this).
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
(DPM) Names for User Scalars (instead of Use Variable 0)? sega Fluent UDF and Scheme Programming 3 April 20, 2010 07:33
error in COMSOL:'ERROR:6164 Duplicate Variable' bhushas COMSOL 1 May 30, 2008 04:35
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 04:27
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
