drag predicitions
Old   April 30, 2001, 06:18
Default drag predicitions
hakeem
Hi everybody ...
As most of you are aware, for creeping (slow) flow of Newtonian fluid moving over a sphere the ratio of pressure
coefficient to viscous coefficient should be ~ 0.5. Unfortunately, when I use Fluent 5.3, it is not the case. The
total coefficient is right, namely, for Re = 0.01, the total drag coefficient should be ~ 2400. I got it 2400.8.
However the ratio of pressure coefficient to viscous coefficient is 640.66629/1760.1434 = 0.36. Could anyone
think of possible reason.
Old   May 2, 2001, 12:33
Default Re: drag predicitions
Xiao Hu
I would do a mesh adaption based on pressure gradient. And then do a second mesh adaption based on velocity gradient. After those adaptions, run it again and see if you observe any changes.
Old   May 7, 2001, 21:12
gangxia
I have the same experience. In most cases, mesh adaption is the key point,because the accuracy of viscous coefficient rely on the mesh quality. I would inspect into the velocity profile and see if the velocity gradient in boundary layer is smooth. That's important, I think.
Pressure drag, friction drag and total drag? Cheng CFX 9 January 26, 2024 13:46
formula used for drag force? kamma Main CFD Forum 0 April 2, 2010 10:21
Drag coefficient for parcels in dieselFoam sebastian_vogl OpenFOAM Running, Solving & CFD 5 December 31, 2008 12:19
anyone has got this paper? Al Main CFD Forum 3 October 8, 2007 02:04
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
