chemical vapor deposition
Old   May 7, 2001, 05:45
Default chemical vapor deposition
Paul Izabel
Hello, I'm working on the simulation of a chemical vapor deposition reactor with trichlorosilane and hydrogen. Fluent comes with a tutorial case for a reactor with silane and hydrogen. In this case the silicon deposited on the surfaces is named "Si(s)" and the parameters for this fluid are in the data-base of fluent. One thing that puzzles me is the value for the standard state enthalpy (heat of formation), which is 381 J/kmol. Shouldn't it be zero? Isn't the heat of formation of pure elements usually zero?? Probably this value won't influence the results, but I'd like to understand it anyway. Thanks, Paul
chemical reaction in stead of combustion wlt_1985 FLUENT 3 June 11, 2012 04:55
Finite rate chemical reactions Marc Segovia Siemens 3 November 28, 2001 04:21
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 00:07
CFD software in Chemical Engg. Rakesh Desai FLUENT 0 November 28, 2000 04:05
chemical reaction - howto Dan Sorensen Siemens 1 February 21, 2000 09:20
