SOS!About water-vapor
Old   May 11, 2001, 22:30
Default SOS!About water-vapor
max
Hi, everyone! IĄŻm modeling water-vapor flows through a converge-diverge nozzle using commercial code. For compressible flows, many commercial codes think the idea gas law is the appropriate density relationship. However, the water vapor IĄŻm using is 0.6Mpa, so in my opinion, it canĄŻt be thought as idea gas. Unfortunately, I couldnĄŻt find the UDF (User Defined Function) for density. Could anybody kind enough to give me some advices on how to set the physical properties. Anything about FLUENT, CFX, or ANSYS is welcome! All thanks given to you for your help!
Old   May 17, 2001, 03:02
Default Re: SOS!About water-vapor
Jin-Wook LEE
For near 0.6Mpa, difference between real density(from steam table) and calculated density(from ideal gas law) is not so big. The difference becomes higher as temperature increases. However, near 1000Kelvin, the difference is about 3%. If you have another alternative for the exact density, I guess that ideal gas law is fairly good approach.
Sincerely, Jinwook
Old   May 17, 2001, 05:04
max
Thank you for your concern! But i wonder whether the ideal gas law still do when the pressure vary from 366.6Pa to 0.6MPa?
Old   May 18, 2001, 03:14
Jin-Wook LEE
1. Please refer steam-table.
2. For every gas, its behavior is similar to ideal gas at low pressure region. The difference is, as I posted, about 3% at P=0.6Mpa. When pressure becomes lower, e.g., 366Pa. the difference between ideal gas law and actual value becomes small. So, I recommend that you use ideal gas law if you can accept maximum error of about 3%(when P=0.6Mpa).
3. Ideal gas law is fairly good alternative till P = 1 ~ 2Mpa for many kind of gases.
Sincerely, Jinwook
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Water vapor condensation be89 Fluent UDF and Scheme Programming 0 September 14, 2011 15:36
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
Injection of water in vapor SimoneTecnoil FLUENT 0 November 9, 2009 11:29
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
