injecting water mixed with tiny bubble
Old   June 16, 2001, 03:03
Default injecting water mixed with tiny bubble
willy
Hi, I am wondering if it's possile to model inlet with a mixture of water and tiny bubbles?
I am modeling a water treatment reactor filled with water.
Again Inlet is a mixture of water and tiny bubbles. Thanks in advance.
Old   June 18, 2001, 02:41
Default Re: injecting water mixed with tiny bubble
Hbet
Yes you can.
You can use multiphase flow algebraic slip mixture model and define volumetric fraction of air at the inlet.
Hbet
Old   June 18, 2001, 07:54
willy
Thanks million. You are my life saver. Actually, I had little idea with that stuff. And I am also wondering if it is possbile to define the diameter of bubble in the multiphase flow algebraic slip model. Can U comment on this matter?
Thanks in advance!!!
Old   June 18, 2001, 08:50
wilyban
I now I get the hang of it. multiphase flow algebraic slip model aske me to input diamenter of second phase material. One other thing. When do we really have to have "Body formce" enabled? I am always confused when it come to this pain in the neck. Thanks in advance smart guys..
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
I want to rotate secondary phase (bubble in water tank) huseyin Fluent UDF and Scheme Programming 0 May 5, 2010 03:00
Modelling of bubble merging submerge on water Carlos Main CFD Forum 0 October 26, 2005 09:30
Hot gas bubble collapse in cool water William Palm FLUENT 1 April 20, 2005 10:53
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
