problem with surface integrals
Old   July 13, 2001, 08:48
Default problem with surface integrals
tibor
on the surface (with an outflow boundary condition) area-weighted average velocity magnitude is smaller then area-weighted average Z-velocity.. how it's possible?
Old   July 13, 2001, 12:39
Default Re: problem with surface integrals
Scott Whitney
I've seen the exact same problem that you are describing. For me thus usually has a less than 1% error. These surface integrals are only approximate, thus one can't be compared to the other. If you have significantly more than 1% error, then there might be an actual Fluent problem and they should be contacted.
Old   July 13, 2001, 17:06
Tamer Elsoukkary
I tested just counter flow in an annulaus where two different fluids are separated by wall and to my surprise when I specified the inlet as velocity inlet for both fluids the surface integral flow rate was changing between iterations! where it should be constant because velocity is specified!!
How can that be possible!!!!
Old   July 16, 2001, 05:07
bas
I've seen the same phenomena and I think it's something like this. Velocity magnitude is a vectorial sum of x-, y- and z- velocity. When you have velocity component besides your primary flow (in z-direction), the velocity magnitude will be larger then the components itself.
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Problem about a 2D surface rotation skyblue_mech Main CFD Forum 0 June 8, 2010 04:49
Surface orentation problem in icemcfd jeevan kumar CFX 0 August 13, 2008 01:54
Creating lines for surface integrals Ale FLUENT 2 October 16, 2002 15:35
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
