Convergence problem
Old   August 13, 2001, 22:46
Default Convergence problem
Jie
I want to calculate the flowfield of one nozzle for certain boundary conditions. In fact, after 30000 interations, the residual fo velocity, energy came to stay the same.But the residual is too big to be considered to be converged. How can I refine the grid to improve the result?
Thanks
Old   August 14, 2001, 03:27
Default Re: Convergence problem
chiseung
Did you set your vicous model properly? I wonder if it was set reasonbly. How about getting k & e value(or turbulence intensity) from papers dealing with simlimar geometry and b.c.?
For grid refinement, as I know, there are two ways. First, build your grid system again in GAMBIT. Second, there is an option "Adapt" in solver.
P.S. : In my experience, in case of turbulent flow problem, there were several cases solved by changing only momentum relaxation factor. Of course, setting a proper relaxation factor is totally depedent on trial and error.
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
