Error when using k-e model !?
Prev Previous Post   Next Post Next
Old   September 6, 2001, 09:09
Default Error when using k-e model !?
Mika
Hi, I'm simulating with Fluent the development of a flow initially at rest under EM forces.
I wrote an UDF which calculates the distribution of EM forces.
However, I have some difficulties to make the solution converge to a "physical solution": I change the solver parameters, the mesh... but nothing seems to change the numerical solution.
Finally, I decided to run the solution wih a k-e model instead of the laminar one. But, before the end of the first iteration, and only when using the k-e model, I have this error message:
Error: > (greater-than): invalid argument [2]: wrong type [not a number] Error Object: nanq
I verified that my UDF gives always correct numbers, and it is.
Thanks for ideas or solutions...
Mika
PS: here is my UDF, as asked in a previous post.
double zmaxi; double pas;
int NbreAimants; double *TabAimants;
int NbreElectrodes; double *TabElectrodes;
real x_fluent[3]; double X[3]; double F[3];
char path[100]="/legi44p/tourn/perrin/DEA/"; /*char path[100]="/legipc65/home/perrin/DEA/";*/ char path2[100];
FILE *debug_x; /*FILE *debug_y;*/ /* FILE *count;*/
DEFINE_SOURCE(emf_x,cell,thread,dS,eqn) {
int i;
double z;
double force[3];
double j;
int it;
/* permet de recuperer le nombre d'iteration */
it = (nres == 0) ? (0) : ((int) count2[nres - 1]);
if(it<1)
strcpy(path2,path);
if((debug_x=fopen(strcat(path2,"fluent/udf/emf7/src/debug_x"),"a"))==NULL)
fprintf(stderr,"Erreur a l'ouverture du fichier debug");
/* strcpy(path2,path);
if ((count=fopen(strcat(path2,"fluent/udf/emf7/src/count"),"r"))==NULL) {
fprintf(stderr,"Erreur a l'ouverture du fichier count 1");
fscanf(count,"%d",&compteur);
fclose(count);
strcpy(path2,path);
if ((count=fopen(strcat(path2,"fluent/udf/emf7/src/count"),"w"))==NULL) {
fprintf(stderr,"Erreur a l'ouverture du fichier count 2");
fprintf(count,"%d",++compteur);
fclose(count);*/
lect_data();
lect_aimants();
lect_electrodes();
/* récupération des points du calcul */
C_CENTROID(x_fluent,cell,thread);
X[0]=x_fluent[0]*1000.0;
X[1]=x_fluent[1]*1000.0;
X[2]=x_fluent[2]*1000.0;
z=zmini;
i=0;
force[0]=0;
force[1]=0;
force[2]=0;
while(z<zmaxi)
X[2]=z;
calcul_force(X);
force[0]+=F[0];
force[1]+=F[1];
force[2]+=F[2];
z+=pas;
i++;
j=(double)i;
F[0]=force[0]/j;
F[1]=force[1]/j;
F[2]=force[2]/j;
fprintf(debug_x,"\nX: %lf, Y: %lf, Z:%lf, force_x: %lf Fx=%f force_y: %lf FY=%fj=%lf\n",X[0],X[1],X[2],force[0],(real)F[0],force[1],(real)F[1],j);
free(TabAimants);
free(TabElectrodes);
/* sauvegarde des valeurs dans une variable */
C_UDMI(cell,thread,0)=(real)F[0];
else
F[0]=C_UDMI(cell,thread,0);
fclose(debug_x);
return (real)F[0]; }
void lect_data() {
FILE *fdata;
char str[25];
strcpy(path2,path);
if ((fdata=fopen(strcat(path2,"fluent/udf/emf7/src/data.dat"),"r")) ==NULL)
fprintf(stderr,"Erreur a l'ouverture du fichier data.dat");
fscanf(fdata,"%s %lf",str,&conductivite);
pi=M_PI;
fscanf(fdata,"%s %lf",str,&unite);
fscanf(fdata,"%s %lf",str,&zmini);
fscanf(fdata,"%s %lf",str,&zmaxi);
fscanf(fdata,"%s %lf",str,&pas);
fclose(fdata); }
void lect_aimants() {
FILE *faimants;
int i;
int j;
strcpy(path2,path);
if((faimants=fopen(strcat(path2,"fluent/udf/emf7/src/aimants.dat"),"r"))==NULL)
fprintf(stderr,"Erreur a l'ouverture du fichier aimants.dat");
fscanf(faimants,"%d",&NbreAimants);
TabAimants=malloc(NbreAimants*6*sizeof(double));
for(i=0;i<NbreAimants;i++)
for(j=0;j<6;j++)
fscanf(faimants,"%lf",(TabAimants+i*6+j));
fclose(faimants); }
void lect_electrodes() {
FILE *felectrodes;
int i;
int j;
strcpy(path2,path);
if((felectrodes=fopen(strcat(path2,"fluent/udf/emf7/src/electrodes.dat"),"r"))==NULL) {
fprintf(stderr,"Erreur a l'ouverture du fichier electrodes.dat");
fscanf(felectrodes,"%d",&NbreElectrodes);
TabElectrodes=malloc(NbreElectrodes*6*sizeof(doubl e));
for(i=0;i<NbreElectrodes;i++)
for(j=0;j<6;j++)
fscanf(felectrodes,"%lf",(TabElectrodes+i*6+j));
fclose(felectrodes); } void calcul_force(double *x) {
double B[3];
double E[3];
int i;
calcul_B(x,B);
calcul_E(x,E);
prod_vect(E,B,F);
for(i=0;i<3;i++)
F[i]*=conductivite;
void prod_vect(double *A, double *B, double *C) {
*C=(*(A+1)**(B+2)-*(A+2)**(B+1));
*(C+1)=-(*A**(B+2)-*B**(A+2));
*(C+2)=(*A**(B+1)-*B**(A+1)); }
void calcul_B(double *x, double *B) {
int i;
int j;
double k;
double surf[6];
double tmpB[3];
for(j=0;j<3;j++)
*(B+j)=0;
*(tmpB+j)=0;
for(j=0;j<6;j++)
surf[j]=*(TabAimants+i*6+j);
k=surf[5];
yonnet(tmpB,x,surf,k);
for(j=0;j<3;j++)
B[j]+=tmpB[j];
void calcul_E(double *x, double *E) {
int i;
int j;
double k;
double surf[6];
double tmpE[3];
for(j=0;j<3;j++)
*(E+j)=0;
*(tmpE+j)=0;
for(j=0;j<6;j++)
surf[j]=*(TabElectrodes+i*6+j);
k=surf[5]/(surf[4]*surf[3]*(pow(unite,(double)2))*conductivite);
yonnet(tmpE,x,surf,k);
for(j=0;j<3;j++)
E[j]+=tmpE[j];
void yonnet(double *C, double *x, double *surf, double k) {
int i;
int j;
double xs[3];
double a;
double b;
double coef;
double S[2];
double T[2];
double R[2][2];
double tmp[3];
for(i=0;i<3;i++)
xs[i]=(*(x+i)-*(surf+i))*unite;
a=*(surf+3)/2*unite;
b=*(surf+4)/2*unite;
coef=k/(2*pi);
for(i=0;i<2;i++)
S[i]=xs[2]-(pow((double)-1,(double)(i+1)))*b;
/* Attention les axes dans le yonnet et dans notre etude ne sont pas les mêmes */
T[i]=xs[0]-(pow((double)-1,(double)(i+1)))*a;
for(i=0;i<2;i++)
for(j=0;j<2;j++)
R[i][j]=(sqrt(pow(S[i],(double)2)+pow(T[j],(double)2)+pow(xs[1],(double)2)));
for(i=0;i<3;i++)
tmp[i]=0;
for(i=0;i<2;i++)
for(j=0;j<2;j++)
tmp[0]+=(pow((double)-1,(double)(i+j))*log((R[i][j]-S[i])));
tmp[1]+=(pow((double)-1,(double)(i+j))*atan((S[i]*T[j]/(R[i][j]*xs[1]))));
tmp[2]+=(pow((double)-1,(double)(i+j))*log((R[i][j]-T[j])));
for(i=0;i<3;i++)
*(C+i)=coef*tmp[i];
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 10:27
