September 10, 2001, 03:37 |
Segragated Solver Error
I am using the segregated solver for multiphase flow calculations. Some of the calculations crash because the volume fraction in one cell (not always the same) is set to 100% while iterating. The values in the neighbor cells are ok only this variable in this single cell has a problem. The result is a floating point exception. Has anyone faced a similar problem. I don"t think it is a problem of my user-defined functions since they work well in other geometries.
Tobias |
OpenFOAM install on Ubuntu Natty 11.04 | bkubicek | OpenFOAM | 13 | May 26, 2011 05:48 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
