shadow elements
Old   October 9, 2001, 07:41
Default shadow elements
santosh
hi,
I am trying to simulate the flow in a cooling pipe of gas turbines.I have modelled it as two volumes on of the pipe and other outside turbine blades.The hole thru which the flow goes out of the pipe is a face on the pipe.I have ensured that there are no two coinciding surfaces.
when I export it to fluent,it creates one shadow zone on the outer pipe surface and grid check fails.Can somebody point out the problem in my model.
thanks and regards, santosh
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 12:51
[ICEM] Negative Volumes & 7 node HEXA elements mr_stoked ANSYS Meshing & Geometry 1 September 21, 2010 12:45
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
