result in negatif value in pressure
Old   December 30, 2001, 04:07
Default result in negatif value in pressure
chong chee nan
hi
for pipe flow, i set the inlet boundary as Velocity Inlet, and outlet boundary as Outflow, on the Initial Window i set compute from inlet boundary with initial gauge pressure = 13332Pa and x-velocity = 0.2m/s. Then i set the Outlet with flow rate weighting = 1. after simulated the pressure at the inlet(<>-75Pa) and outlet(-153Pa) shown in negatif value. what are the procedure and formula used to get the negatif value. The condition under simulated were laminar, steady, 2d, segregated solver and newtonian fluid.
Old   December 30, 2001, 10:06
Default Re: result in negatif value in pressure
HVN
In cfd software, you always use the relative pressure. So you could have a negative relative pressure with a positive pressure.
Pressure averaging at the outlets. KM CFX 6 April 1, 2021 06:28
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 13:45
Boundary Conditions : Total Pressure or Velocity Gearb0x OpenFOAM Running, Solving & CFD 2 February 28, 2011 21:18
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 17:19
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
