flow patterns
Old   January 3, 2002, 05:07
Default flow patterns
gorman
I think fluent will never able to show flow patterns in pipes.Please tell me any scheme that could be use to this purpose? Thank you
Old   January 3, 2002, 05:18
Default Re: flow patterns
John
Do you mean secondary flow in the cross-section of the pipe?
Old   January 3, 2002, 09:30
gorman
hi,
i am trying to stimulate a segregated flow and/or observe flow patterns such as wavy flow, bubbly flow,slug flow etc. As i am dealing with 2 phases (CO2 and oil), i wish to observe the flow patterns of both phases in a vertical pipe and a horizontal one.
Please advise,Thank you.
Old   January 4, 2002, 05:55
John
In this case, only Fluent guys can answer it.
Old   January 4, 2002, 11:08
gorman
Thanks,
However, please advise me of what in your mind? I wish to discuss more around the focus. How about the secondary flow in the cross sectional area that you mentioned?
Old   January 5, 2002, 15:43
John
You have to use a non-isotropic turbulence-model.
Old   January 6, 2002, 22:17
gorman
how do I set my model to a non-isotropic turbulence model? I am doing a vertical pipe. Thank you.
Old   January 9, 2002, 12:22
Lanre
So you are trying to model vertical two-phase gas-liquid flow. The multiphase models in FLUENT 6 are capable of modelling the various flow regimes you are interested in. The many multiphase models are developed for certain types of flow regimes. Hence, you may not be able to model flow regime transitions from surface-dominated to inertial-dominated flow regimes, e.g., dispersed to plug. You can model transitions, say from plug to slug in a vertical flow or stratified to wavy to slug and possibly even annular in a horizontal flow.
Take a look at the training notes on multiphase flow to guide your selection of model and fit to range of flow regimes at http://www.fluentusers.com/fluent5/training/9amulti.pdf
Old   January 10, 2002, 02:36
gorman
Thanks alot, u mentioned FLUENT 6, how about FLUENT 5.0? is it possible also?
Old   January 10, 2002, 09:50
Lanre
Some of the flow regimes you describe would be more accurately modelled using the Eulerian multiphase models that are available in FLUENT 4.5 and FLUENT 6 but not FLUENT 5.x
Old   January 10, 2002, 11:16
  #11
gorman
To model vertical two-phase gas-liquid flow for CO2 and fuel-oil-liquid, Do you think using k-epsilon viscousity is proper? What assumption has to be made in using laminar flow? I am not sure how FLUENT would define both cases. Thank you for your advise.
Old   January 15, 2002, 14:33
  #12
Lanre
I don't think the k-e turbulence model is "proper" in the absolute sense of the word for either single or multiphase flow problems. The deficiencies are well known and are published in the literature. For multiphase flow calcs in FLUENT, the k-e model can be used to model the turbulence in the primary phase only or in both the primary and secondary phases independently (four equations solved for two phases). There are documented rules on which of the two approaches is most valid for specific applications. If the flow is laminar, you don't have to use a turbulence model at all.
Old   January 16, 2002, 17:17
  #13
gorman
How can I determine whether it is gonna be a laminar flow? I am modeling gas lift system, pumping high velocity gas into well shoe and pump up the crude oil to the well head. Can it considered a laminar flow?
I have also determined to choose ASM model as gas and oil will form a "uniform' body and transport upwards.Do you think my set up is proper? Thank you.
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 10:30
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Flow Patterns Andy FLUENT 0 April 1, 2003 18:46
Instability and Vortex/roll structure Z. Zeng Main CFD Forum 3 May 10, 2000 05:18
