differences between 5.4 and 5.5
Old   January 7, 2002, 06:07
Default differences between 5.4 and 5.5
phil
Can anyone shed any light onto why running exactly the same model in 5.4 and 5.5 is giving different solutions?
Old   January 7, 2002, 22:19
Default Re: differences between 5.4 and 5.5
Greg Perkins
Check Fluent users website for bug updates. The differences are probably due to fixes in 5.5 that are not in 5.4, ie there are bugs in 5.4.
One would think that later versions are better, but this isn't always so. To be honest, if you can't find a reason from the bug fixes, its going to be a hard slog to work out the cause. To some extent choose the one you're happy with (your validation) and stick to it. Its a never ending saga with updates, otherwise.
Greg
Old   January 8, 2002, 03:57
phil
Cheers Greg. I couldn't find anything obvious, it could I suppose be differences in the platforms, I am running 5.4 on unix and 5.5 on NT.
Old   January 8, 2002, 04:21
Greg Perkins
Yeah - who knows!?
I know there were a few bugs - though nothing major in 5.4.18 (I think).
It depends on how different - if you're using single precision on one and double on another computer then that is likely to have an effect.
If the difference is large then it probably is something in the code - but its almost impossible to work out what.
Check if any default values have changed too...although I don't remember anything major.
I suppose, you can see how different 6 is now!!!!!!! That will give you three answers to consider!
Greg
Old   January 8, 2002, 04:28
phil
I guess if I run it in 3 versions one of them is likely to kick out the answer I want! Not sure thats the best modelling strategy though!
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
Help: 2D model in CFX 5.5 Dejun Jing CFX 1 July 24, 2002 00:25
Fluent 5.5 can't solve Multiphase+Multicomponent? Thitikorn FLUENT 8 March 27, 2002 22:57
2D in CFX 5.5 (2) Astrid CFX 5 December 21, 2001 00:09
Fluent 5.5. What the differences with fluent 5.3?? confused FLUENT 2 July 29, 2001 21:58
