January 30, 2002, 21:52 |
emergent! hot to simulate mcvd process ?
hot to simulate the reaction: SiCl4(g)+O2(g)-->SiO2(s)+2Cl2(g) in fluent,how to carry out it!
January 31, 2002, 03:18 |
Re: emergent! hot to simulate mcvd process ?
the reaction take placed in gas phase. how to simulate it? plz tell me.
January 31, 2002, 03:34 |
the reaction as following:
--------------------ĄŁ-ĄŁ----------- -----> o SiCl4+O2 -----> o SiO2 particle -----> o ĄŁ ĄŁ ------------------------------------ |
January 31, 2002, 17:33 |
Look in manual under surface reactions. Have a look at some of the tutorials.
Greg |
February 4, 2002, 09:02 |
Re: emergent! how to simulate mcvd process ?
thank your message, but the reaction takes place in gas phase, which is volumetic reaction not a surface reaction. the particls,sio2, generated in gas, the the particle deposits on the surface due to the thermophosis force. in fluent, what to do for the chemical reaction with particle model. in the side, there are some paper for mcvd, but how to carry out it?
February 4, 2002, 19:35 |
OK, well I don't know your process, but here's how I normally approach such problems:
1) write down the governing equations, bcs for your problem 2) compare them with Fluent and its models 3) if same use inbuilt Fluent models 4) if different use udfs and/or uds scalars to transform Fluent so it solves eqns (1). In some cases, you can't transform Fluent to solve (1) due to Fluent's limitations, in that case you need to change your problem deifinition (1) or use another code. So you're problem involves small particles/molecules of solid being formed in the gas phase and then transported to the wall?! Depending upon how much detail you want/need to model, I imagine you can transform his into a surface problem. To actually model the transport of material from the gas phase to the wall could be difficult in Fluent. Ask Fluent more about it. Greg |
simulate the drying process | Valpress | FLUENT | 8 | April 25, 2018 10:23 |
Simulate melting process of solid aluminium in liquid Titanium | anirudster | CFX | 8 | March 21, 2014 09:20 |
Which CFD software is suitable to simulate melting process? | sosososo1114 | Main CFD Forum | 1 | March 12, 2010 11:40 |
how to simulate evaporating process of refrigerant | chingyou | FLUENT | 0 | October 25, 2005 21:41 |
Could Fluent simulate random process? | David | FLUENT | 0 | September 6, 2002 10:49 |
