flow around a circular object
Old   February 7, 2002, 02:15
Default flow around a circular object
Mavinakere
Hi, I want to visualise flow of water around an circular object. i'm solving a 2d problem here.i have 1 inlet and 1 outlet and the bottom is a wall.but,the top is a free surface. how do i set the top as a free surface? and what other boundary conditions can i apply for a incompressible flow? thanks.
Old   February 7, 2002, 02:56
Default Re: flow around a circular object
Greg Perkins
For free surfaces you'll need to use the vof model. But before that try a run without the free surface and choose say a non-slip wall.
Greg
Old   February 8, 2002, 18:03
jim clancy
just set the flow speed and the pressure, this will work,,good luck.
Old   February 10, 2002, 14:27
Mavinakere
How do i set non slip wall?coz in the wall boundary condition,i have options for wall roughness,moving wall and specified shear stress. Mavinakere.
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
flow in a non circular culinder-piston s_fardisi FLUENT 0 February 24, 2010 20:46
Oscillating Flow in a Circular Pipe Johann Ott CFX 3 March 2, 2009 16:42
Circular Couette Flow rockewan FLUENT 0 April 12, 2008 15:26
Modeling flow acros circular cylinder Zhihua Main CFD Forum 3 April 20, 2004 11:16
