Mass flow rate on outflow face
Old   February 25, 2002, 03:36
Default Mass flow rate on outflow face
TOM
HI,
I've got a simple pipe with an inflow and an outflow. I just would like to know the mass flow rate on the outflow face. How Fluent (5.5) can tell me it (using graph or calculations)?
Thank you so much, looking forward any idea.
TOM
Old   February 25, 2002, 10:27
Default Re: Mass flow rate on outflow face
chiseung
If you solve the momentum equations(x,y,z), you can get the average velocity at the outflow face.
(Report->surface integral)
Then you can simply calculate the mass flow rate with the equation "mass flow rate=rho*area*velocity".
calculate mass flow rate on face OpenFoam ronaldo OpenFOAM 7 November 8, 2019 00:10
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
mass flow rate on the Iso-clip surface & interior Sunil Gupta FLUENT 0 April 22, 2008 09:29
sos! How to define the flow rate of outflow BC? zjm FLUENT 0 June 4, 2004 09:12
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
