February 25, 2002, 18:18 |
3d-pipe intersection in same plane
I have drawn 3 cylinders(of diff.dimension) in same plane and united them using a sphere.But when i try to SMOOTH/SWAP it in FLUENT ,the error message says non positive volume exists.
Kindly tell me where i am wrong? |
February 26, 2002, 10:49 |
Re: 3d-pipe intersection in same plane
I have gotten negative volumes in the past by meshing a volume with tets and then have Gambit smooth it. I solved that by either 1) not smoothing in Gambit or 2) use different meshing intervals and play with the settings a bit. Optimizing the face meshes before meshing the volume can do wonders.
After reading the mesh into Fluent, run a Grid Check and confirm if the mesh contains these negative elements already from the beginning. Or check the mesh in Gambit to find these negative elements. Also, face swapping inside Fluent does not work for hex or hybrid meshes. You can only use the smoothing option. |
February 26, 2002, 12:43 |
how do i prevent myself from not smoothing in Gambit because i dont do it myself as an operation. If i do not swap then my iterations are not starting.It says 'Divergence detected'.
February 26, 2002, 13:56 |
Is the negative volume created in Gambit? If so, try changing the face mesh very slightly, e.g. by changing the interval 0.01 or by moving some nodes. Play with it. Then remesh the volume and check if negative elements keep appearing. If have found that stubborness is essential when using Gambit.
Divergence can be created by lots of things: bad initialization, forgetting to scale the grid, etc. Start slowly, for example with adiabatic incompressible flow and gradually turn on more features. Start with 1st order discretization and low URF values. Limit pressure and temperature values to realistic numbers. |
[GAMBIT] 3D mesh for pipe intersection | pranab_jha | ANSYS Meshing & Geometry | 3 | May 28, 2010 01:33 |
meshing at a pipe intersection | cyn | FLUENT | 0 | December 20, 2006 02:16 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
