LINEAR SIZING FUNCTION SHOULD BE ATTACH?
Old   February 26, 2002, 00:58
Default LINEAR SIZING FUNCTION SHOULD BE ATTACH?
rslgp
hi, some times, while generating mesh on the face in gambit, i am getting the following message. i.e., " Linear sizing function should be attached to the face." what is meaning of this message?
Old   February 26, 2002, 02:56
Default Re: Linerar sizing function should be attach?
Jonas Larsson
Yea, I've also always wondered about that. It seems to happen when you have large/complex faces. The grid usually looks okay even when you get this error message though.
Anyone know what implications this error message really has? How can you avoid it and what problems can you expect when you get it?
Old   February 26, 2002, 12:53
Amadou Sowe
The sizing functions are a new set of tools that are designed to help us avoid a lot of domain decomposition in the case of complex geometries. They can also be used to put say several layers of tets in narrow regions of geometries.
I think the message is just suggesting that the meshing could be done much more easily by using size functions. So if you can mesh your domain successfully I would suggest that the message can be neglected. But if you cannot mesh your domain successfully, then Gambit is suggesting that the use of size functions may be very helpful in your case.
This is the most useful feature I have seen in Gambit in a long time. I think the Gambit team should be working very hard in making the sizing functions work better.
Old   February 26, 2002, 13:25
Jonas Larsson
Hmm... I have seen this message many times in gambit 1.x, hence I don't think it has anything to do with the new sizing functions available in 2.x.
Old   February 26, 2002, 14:35
Amadou Sowe
You might be right, but it is also possible that adding size functions was in the works since Gambit 1.X.
May be some one from the Gambit team can clarify this.
Old   February 26, 2002, 17:54
Shyam Kishor
Yes, Amadou's observation is correct. The idea of the Sizing function was from the beginning but the implementation got delayed due to other priorities.
Old   February 27, 2002, 00:55
Shailendra
This message was indication of greatly varying sizes on the colloiding fronts. Now this message has been replaced in Gambit2.0 Qaud paving by more intelligible message . The new message is:
"The interval sizes vary greatly on the boundary of face . Although meshing will be attempted, it may be best to adjust interval sizes or attach an appropriate size function to the face."
Old   February 27, 2002, 13:32
rslgp
THKS FOR CLEARIFYING. BYE
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 04:37
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
