February 27, 2002, 14:19 |
UDF and turbulence
Hi everyone.
I'm VERY new to UDF programming so this might be a rather stupid question for the experienced. Anyway, here it is: Is it possible to modify the C_mu value of the k-epsilon models with a UDF? If so, how is it done? I'm trying to make the C_mu value a function of local turbulence properties. Thanks.. |
February 28, 2002, 03:46 |
Re: UDF and turbulence
I suppose You can't do it directly, but You could modify a Turbulent Viscosity (Fluent 6) and than You can set inside what You want (coefficients, function of arbitrary form etc).
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Can Fluent Import New Turbulence Model By UDF? | Andy Cong | FLUENT | 4 | March 25, 2016 13:14 |
problem with UDF for (v2-f) turbulence model in fluent | artemiss1984 | Fluent UDF and Scheme Programming | 6 | January 17, 2014 05:50 |
UDF for turbulence model | zzr | FLUENT | 1 | March 17, 2002 18:34 |
UDF & Accessing Turbulence Properties | Dimal | FLUENT | 0 | March 5, 2002 13:14 |
