GAMBIT error
Old   March 11, 2002, 13:22
Default GAMBIT error
Phil
I am having trouble meshing some geometry I have imported from Pro/Engineer.
I get the error ACIS error 5000 : coincident face_face_ints with different body vertices
The geometry seems to mesh with tets ok but i cannot split the volume so that i can have greater control over the meshing. Trying to export as Iges does not work either.
Can anyone help me get round this and/or explain exactly what the error message means?
Old   March 11, 2002, 14:20
Default Re: GAMBIT error
Erwin
As I suggested in a previous post (http://www.cfd-online.com/Forum/fluent.cgi?read=7041) you should check for duplicate vertices, that has helped me several times. Tet meshing sometimes works with such degenerate geometry but it either generates a sliver or even a cell with negative volume.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
