March 19, 2002, 13:18 |
mass diffusion coeff. of water-liquid
hi cfd's
can anybody tell me the value of mass diffisivity of WATER-liquid? I am using water-liquid as tracer in a tank containing water-liquid (both having same properties). Hence i am need of numerical value of mass diffusivity of water-liquid in water-liquid.(K-e turbulence model) thanks in advance. bye l.g.patil |
March 20, 2002, 05:04 |
Re: mass diffusion coeff. of water-liquid
Hi again! Did you read my answer from yesterday? Yvonne
March 20, 2002, 08:10 |
hi i have read it but, somehow my fluent answers are not matching with expt data. trend is ok but other characteristics are matching. i am expecting some problem related to diffusion coeff. if you have any other ref. pl convey at the earliest. presently i am using mass diff of mixture( water- water) as 3.0e-9 bye
March 20, 2002, 11:29 |
hi! The other characteristics, which are not matching correctly...they are dependend on the mass diffusivity? I mean, there are so many things to define, you think mass diffusivity is the one which is wrong? Yvonne
March 20, 2002, 11:55 |
March 21, 2002, 09:34 |
Hi! Did you write anything?I can't read your text! Yvonne
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
Help with mass transfer in heat and water vapor exchanger | mullenc525 | CFX | 7 | January 25, 2011 23:26 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
Mass Diffusion via UDF | Ryan | FLUENT | 4 | February 13, 2003 00:10 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
