Convergence problem, HELP!
Old   March 27, 2002, 11:26
Default Convergence problem, HELP!
Roger
Recently I simulated solid-liquid suspension problem in stirred tank with MIXSIM and Fluent4.5. I first create mesh with MIXSIM (with 0 interation), where multiple reference frame was used. Then I define and patch the solid phase in Fluent4.5. I had tried different underrelaxation, but can not get convergened result.
The question is: If I select one equation(with unselect other equations in Selet Equations panel)one time and get the convergened result for this equation, then I solve all equations one by one in this way , is this result correct or is this result real convergened one? If not, how to get the convergened result?
The basic case parameters are: liquid: water, solid: wood particle (Diameter: 0.5mm, volume fraction: 0.1, density: 700 kg/m3), no heat and mass transfer.
Any suggestions are appreciated.
Roger
convergence problem when use pisoFoam, LES for wind tunnel case Forrest_Lei OpenFOAM 3 July 19, 2011 06:00
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
Non Convergence of 3D Heat transfer cfd problem Balraj Main CFD Forum 3 December 9, 2004 00:24
