Line problems
Old   March 20, 2002, 11:00
Default Line problems
Atholl
Hi, I'm now post-processing on my 3D half annulus in the form of creating lines through the geometry (parallel to the Y axis) at regular axial intervals and producing x-y plots of the velocity, viscosity profiles etc. The geometry runs along the z axis, so I'm setting lines (surface>line/rake menu) at intervals along this which was ok until a certain distance along the z axis, where the lines are being displayed as just one or two dots. At further points along the z axis Fluent wont even create the line, giving an error. My coordinates for the lines are fine as far as I know (all I am changing after the first line is the z (axial) value) Any comments will be gratefully accepted!
Old   March 20, 2002, 11:31
Default Re: Line problems
Yvonne
Hi! We had problems with creating lines, if we had values from 0 to something and it worked, if we did it with 0.000001 to something. Dont ask me why. Yvonne
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 07:59
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen su_junwei OpenFOAM Meshing & Mesh Conversion 2 July 26, 2008 23:58
[blockMesh] BlockMeshmergePatchPairs polyTopoChanger benru OpenFOAM Meshing & Mesh Conversion 3 June 29, 2008 21:24
