unconditionally stable VOF calculation
Old   May 9, 2002, 01:03
Default unconditionally stable VOF calculation
chriss
I am having trouble getting a VOF simulation to converge. The problem is water sloshing in a tank.
The tank moves at some acceleration and to simulate that I change the gravity vector. After 50 to 100 time steps at 0.0025 time steps the problem suddenly looses convergence.
The gravity profile is a ramp-up and ramp down with the maximim at about 7.5m/s/s. If I run a step function with the same maximum everything works fine the the problem runs to equilibrium
So the question is, is there a way to make the fluent algorithm unconditional stable, or at least more stable than it is using PSIO and body-force weighted pressure descretization.
Question:Considerations about the evaporation in VOF dokeun FLUENT 10 February 24, 2011 20:47
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 08:46
Enthalpy calculation in VOF David FLUENT 0 October 22, 2008 04:44
Warning 097- AB Siemens 6 November 15, 2004 04:41
Moving mesh or VOF? Giovanni Main CFD Forum 16 September 24, 2001 08:25
