Routine call in UDF
Old   May 21, 2002, 03:49
Default Routine call in UDF
Christian
In the UDF manual on page 4-85 there are an UDF example there they manipulate with the swelling index. In the routine they start off by calling the standard evaporation routine to calculate the mass and heat transfer [VaporazationLaw(p)].
My question: Why is this necessary. I thought that the definition of which laws to use was done elsewhere. Does this mean that when you use UDF's the other laws wont be used unless it is defined in the (first) UDF ? If not, can anyone see the reason why this call is necessary.
Cheers Christian
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 11:03
UDF call function naftalena FLUENT 0 September 27, 2010 04:12
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
2D CFD code using SIMPLE algorithm bfan Main CFD Forum 3 June 22, 2002 22:01
