Home > Forums > FLUENT
Udf for heat source
Old   May 23, 2002, 10:40
Default Udf for heat source
Thomas
A porous medium is included in a domain. I want to define a heat source to the porous medium which will be a function of the temperature difference between the porous temperature and the domain temperature. Thanks for any help, Thomas
Old   May 23, 2002, 21:08
Default Re: Udf for heat source
Keil
It's possible. The DEFINE_SOURCE macro is available for your problem.
Keil
Old   May 23, 2002, 22:52
Greg Perkins
If you're using the standard porous media model in Fluent 5 or 6 you won't be able to model interphase heat transfer or have a model that assumes non-equilibrium between the two phases. Fluent assumes, a single energy equation for solid and fluid as described in the manual.
To model a porous media without thermal equilibirum you need to use udfs/udss...
I have presented some code for this in 2000 and 2001. Its also in the udf repository....search the archives for the posts/code.
Greg
Old   May 30, 2002, 04:12
Laika
Interesting,
where to find this udf repository?
thanks in advance,
Laika, still orbiting
Old   May 30, 2002, 04:36
Greg Perkins
Repository at
ftp://ftp.cfd-online.com/fluent
and my code at
ftp://ftp.cfd-online.com/fluent/udf_scalar_dos.c
Greg
Thread Tools
Trackbacks are On
UDF for energy source João Fernandes FLUENT 4 October 17, 2008 04:53
UDF - source terms Fred FLUENT 2 October 11, 2005 20:53
help on UDF mass source shao1 FLUENT 2 July 11, 2002 20:36
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
