pressure boundary condition
Old   May 21, 2012, 06:19
Default pressure boundary condition
hamid
hamid1 is on a distinguished road
Hi All
Is it possible to set all the boundary conditions, "pressure outlet"?
this is to create a vacuum in a pipe with a stationary fluid inside ..
hamid1 is offline   Reply With Quote
Old   May 21, 2012, 07:11
kumar ravi
ravi_cfd is on a distinguished road
hi,
without an inlet ..its not possible to define an outlet.
so not possible to define all the boundaries as outlets.
ravi_cfd is offline   Reply With Quote
Old   May 21, 2012, 08:37
hamid
thanks for reply,
the idea is to apply an aspiration in a domain which is initially still (no fluid movement before applying the aspiration force), and after applying the aspiration force the fluid should move from inlets to the aspiration boundary (aspiration boundary = minus static pressure or minus pressure outlet)
do you think i have to impose inlet pressure at inlets,
p.s. i imposed pressure outlet on every boundary, it actually works but the results is not correct to me ..
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 10:54
Pressure boundary condition C-H Kuo Main CFD Forum 18 September 16, 2016 03:19
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Pressure Boundary condition abishek FLUENT 1 July 28, 2008 08:14
