case files created by Setupgrid
Old   June 21, 2002, 05:54
Default case files created by Setupgrid
Federico Salimbeni
Dear All,
I'm trying to read a mesh (created by Setupgrid, a Centaursoft product, and converted in a .cas file by Hybconvert) using Fluent 4.5 but it doesn't succeed in doing that operation, and gives an input error. I used the command File/read/Case. Fluent displays the message: (*)- ERROR READING CASE FILE. (*)- SECTION ID=******, LABEL=" (*)- ABORTING READ. I'd like to know if there is any other thing to do or any problem with Fluent 4.5 or in the files created by Setupgrid. Thank you, Best regards, Federico Salimbeni.
Video from case and data files girino FLUENT 9 March 29, 2010 02:41
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Different case files activate ALE Eq. kevin FLUENT 0 November 2, 2006 13:39
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
