udf
Old   July 7, 2002, 09:28
Default udf
heidari
HELLO TO EVERY ONE, CAN YOU HELP ME AND INFORM ME ABOUT udf . I WANT TO DEFINE A VELOCITY DISTRIBUTION AT INLET BUT I JUST KNOW THE MAGNITUDE OF VELOCITY AT CERTAIN POINTS, AND I HAVE NO PROFILE AS AN EQUATION. DOES ANY ONE KNOW HOW I CAN DO THAT.
Old   July 8, 2002, 01:28
Default Re: udf
anindya
Plot the discrete velocities at the specified points using some software like e.g. excel. You can get the best fit profile/curve for the curve. Then after getting the equation of the velocity profile, you can use UDF (macros)to define the profile and run Fluent(see the UDF manual..Sec 1.7 A Step-by-Step UDF Example). Else you can write the velocity and its x,y,z locations in fluent format. This is easy too. See the fluent manuals (User Guide, section 3.3 Reading and Writing Case and Data Files)for that.
Good Luck
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
