Graphics Error...Help needed!
Old   July 20, 2002, 11:35
Default Graphics Error...Help needed!
Stefan
I installed Fluent on a new computer and when i start Fluent, read a mesh file and want to diplay e.g. the grid, the window which opens is completely white and it reads the following message in the Fluent window: Error: Fluent received a fatal signal (ILLEGAL INSTRUCTION) Error Object: () does anyone know what to do? Thank you very much in advance! Stefan
Old   July 23, 2002, 19:53
Default Re: Graphics Error...Help needed!
Matt
Stefan, You may have some OpenGL problems. I know I have that same problem when working with our UNIX emulators. If you are using a unix box, you might want to export the graphics as x-windows. Use this command in your command line
%fluent -driver X11
Matt
Old   August 1, 2002, 09:51
Stefan
Thank you Matt for your reply, i finally made it with the command: Fluent -driver msw i also contacted the company (Matrox) if they can give me further help. Stefan
ANIMATIONS IN BATCH MODE Arianna FLUENT 1 January 31, 2008 09:04
Fluent and Silicon Graphics workstation Swati Mohanty FLUENT 0 September 24, 2006 23:02
a dissertation in ETD needed very much LiQiang Main CFD Forum 0 March 11, 2005 03:09
How to change and fix the size of graphics window? Rob FLUENT 1 February 7, 2003 10:15
Problem: graphics display in prostar main window Jiaying Xu Siemens 8 February 14, 2002 08:08
