mass transfer from fluids to membrane
Like Tree1Likes
  • 1 Post By Peter
Old   August 2, 2002, 14:27
Default mass transfer from fluids to membrane
Peter
I have some difficulty in modeling mass transfer in a membrane separation process. My question is: how to couple mass diffusion in a solid-like (not porous) membrane with mass transfer near the membrane surface?
1. Case description. Binary Fluid (with species B dissolved in water) flowing through a flat slit (2mm high, 20mm wide, 190 mm long). The bottom of this rectangular geometry is a nonporous membrane. Species B will be PREFERENTIALLY permeate through membrane to reach the other side of membrane where a high vacuum is applied.
I use Gambit and Fluent 6. The difficulties I encounted included:
1) Fluent can just take membrane as SOLID, in this way I have no way to input diffusivity of B within membrane. Membrane in this case is still( not moving), yet it is not impermeable solid like steel.
2) How much B should go into membrane should be determined by concentration of B at membrane surface in contace with fluid. As Fluent seems to provide no model for mass diffusion in solid, I compromised to used surface reaction deposition model for this purpose. But in this way, the reaction rate is pretty arbitrary, though I can finally deterine the correct value by error-and-trial approach to let flux from fluid into membrane be the same as the flux through membrane to vacuum.
Thanks for your help,
Peter
sunshine8930 likes this.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
mass transfer in ANSYS thipps ANSYS 1 August 29, 2013 11:05
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
mass transfer coefficient for boundary condition niek Main CFD Forum 0 March 29, 2011 05:33
additional variable mass transfer in CFX5.6 john CFX 1 February 14, 2004 00:30
