August 18, 2002, 05:29 |
Mix flow impeller redesign
I am into redesign of a mix flow pump impeller. Outoff the listed parameters which parameters would be most important to consider them for the further CFD analysis using FLUENT, 1. Blade inlet angle 2. Blade outlet angle 3. Angle made by absolute velocity of fluid and blade at inlet and outlet 4. inlet and outlet areas 5. Number of blades I fill only first two parameters should be considered for the CFD analysis to redesign the impeller. I need your valued suggestion in this regard. Thanks and Regards, Prasad L. Kane |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Volute outlet flow into impeller inlet | Anthony_impeller | CFX | 4 | December 13, 2011 16:17 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
The Effect of impeller type on flow pattern | lee ji hyun | Main CFD Forum | 1 | January 26, 2000 08:35 |
