September 4, 2002, 11:37 |
special injections----Help!
Hello, everyone! I'm going to simulate a kind of special injections, which have different positions at different time. Who can tell me how to do it? Thanks a lot!!!
September 5, 2002, 07:07 |
Re: special injections----Help!
Hi Fanadam,
You can inject particles in different positions at different times using, Define->Injections->Create-> and in point properties you can specify the position of the point, start time and end time of the particle. If you are injecting multiple particles go to Injection type->Group. I Hope this helps! Sridhar. |
September 6, 2002, 04:20 |
A) Save the journal when you inject one set of particles B) Copy that journal whatever times you want and modify the injection type, time...
DC |
September 6, 2002, 11:11 |
Thanks, anyway! But I can't define the initial time or end time at Define-injection-creat. There are no the options in the panel at all. Do you know the reason?
September 6, 2002, 11:24 |
If you like, you can send the case file to me. I will see if I can do anything.
Sridhar. |
Defining DPM Particle Injections with a UDF | TedBrogan | FLUENT | 0 | April 18, 2011 16:45 |
Coal Injections problem | Carlo | FLUENT | 0 | September 30, 2009 06:15 |
DPM injection | ritmat | FLUENT | 6 | June 26, 2007 02:38 |
injections | Donia | FLUENT | 4 | June 2, 2007 06:40 |
About special purpose FLAIR | Constantinos Constantinou | Phoenics | 1 | June 11, 2001 22:45 |
