simple problem
Old   August 30, 2002, 09:33
Default simple problem
Taher
I am working on a purge tank model but to start that analysis I made a simpler model. A 2 D rectangle with a inlet pipe and outlet pipe. The enitre geometry was defined as a single face and quad mapped for simplicity. In Fluent- Pressure Inlet was defined as 1 psig
and Pressure Outlet as 0 psig. Upon solving this model Fluent gives me this error of Error ivergence Detected in AMG solver .
Any clues? Thanks in adavance.
Old   September 1, 2002, 10:43
Default Re: simple problem
sri
Please dcrease the urfs in case of seg solver or courant number in case of coupled solver.
Old   September 3, 2002, 10:32
Sridhar
You may also like to check your turbulence quantities' specification at your inlets and outlets. Sometimes this might be the reason for the 'divergence detected in the AMG solver" error. If both these methods do not work (ie., the urf reduction and the correct turb specs) you can try with different initializations. Hope this helps.
Very simple natural convection problem Naseem FLUENT 19 December 17, 2020 16:00
A simple problem with mfix joshzrr Main CFD Forum 2 October 31, 2013 04:11
Problem with simple if-comparison sega OpenFOAM Programming & Development 3 September 8, 2009 07:21
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 09:11
a VERY SIMPLE problem Andrew MacAulay Main CFD Forum 3 August 23, 1999 10:39
