Problem trying to use a backpressure
Old   October 13, 2002, 12:08
Default Problem trying to use a backpressure
Stephen
The geometry for my model is a that of a sudden expansion duct. I am only using air as my fluid. The airflow inlet has a Mach # of 2.5. I am trying to create a back pressure at the outlet to affect the upstream interaction. The backpressure simulates the injection of a gas normal to the flow. My problem is that if the outlet is locally supersonic then FLUENT extrapolates the pressure upstream and basically ignores the backpressure value given. I want to know what can I do to correct this problem so that the backpressure I gave gives the correct solution from other numerical results. Thanks.
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
