isotropy
Old   October 22, 2002, 07:14
Default isotropy
kim
What is the isotropy of turbulence ?
Old   October 23, 2002, 05:16
Default Re: isotropy
Laika
in brief: turbulence = fluctuations.
If you assume isotrophic turbulence, you assume these fluctuations are the same in all directions, and that the effect is the same in all directions.
This assumption is not always correct. In wall bounded flows or swirling flows for example, the effects of turbulence are not isotrophic.
hope this helps
Laika, still orbiting
Old   October 23, 2002, 06:54
Mark
Hi Laika,
Is the Ke-turbulence model based on the isotropic assumption? If so does this mean it can not be used in swirling flows or internal flows?
Thanks
Mark.
Old   October 24, 2002, 03:38
Laika
Indeed, the basic ke-models are isotrophic, and that's one of the main disadvantages. Fortunately, Fluent has also the RNG variant available: that's the one to use with swirling flows. The RNG variant is not isotrophic and even has a 'swirl dominated flow' option.
greetings,
Dissipation local Isotropy Kolmogorov Idea Hatef Main CFD Forum 3 November 9, 2007 15:52
How aspect ratio affects k-e isotropy? JJ FLUENT 1 May 31, 2001 16:10
