October 28, 2002, 03:36 |
Gambit error
Hi All, I am creating two 2d zones (fluid 1 and fluid 2) with a common boundary line. By default, fluent should consider this common boundary line as ineterior, unfortunately is is considering this as a "wall". Can any one suggest how to overcome this prob?
So far I remember, this was not a prob earlier. DC |
October 28, 2002, 04:25 |
Re: Gambit error
Is it a multiphase problem? Did you specify a multiphase model in Fluent? If not, your problem is logic: Fluent cannot handle an interior between two different phases without a multiphase model selected.
If you really need an interior, check the geometry in Gambit. Is your geometry connected? Laika, still orbiting |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
Accessing phi from a fvPatchField at same patch | johndeas | OpenFOAM | 1 | September 13, 2010 20:23 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
compile errors of boundary condition "expDirectionMixed" | liying02ts | OpenFOAM Bugs | 2 | February 1, 2010 20:11 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
