Freezing 2-D, 2-phase, transient fluent simulation result to 3-D |
December 10, 2015, 00:11 |
Amol
Rep Power: 11 |
Hello All,
I am simulating a 2D, 2-phase transient model with Moving Reference Frame in ANSYS Fluent 16.0. I want to freeze the time averaged volume fraction of second phase obtained from 2D simulation into a 3D domain. Can anyone help me how to do this in Fluent?? Any help is really appreciated. Thanks & regards, Amol A |
December 10, 2015, 22:48 |
Lucky
Rep Power: 66 |
You should be able to write an "interpolate" file. And then read this file into your 3D case. I think Fluent uses 0th order interpolation (nearest) which hopefully gives what you need. I still think you should perform some iterations on the 3D domain to get rid of any inaccuracies from the mapping procedure.
Do you already know how to freeze the variables after? You disable some equations, or use the freeze feature. |
December 13, 2015, 22:32 |
#3 | |
Amol
Rep Power: 11 |
Hi LuckyTran,
Thank you so much for the reply and sorry I could not revert back as I was out of town. Actually what I understand from your suggestion is that once I run 2D simulation, I can write an interpolate file for volume fraction of second phase and then import this file into a 3D domain. What I really want is, I want to time-average the volume fraction of second phase for various times (e.g time-average volume fraction profile from say 0-2 seconds, 2-4 sec, 4-6 sec....). SO I will be having a different time-averaged profile at different times. Then I want to use these different profiles at different times in 3D simulation. I hope I could make myself clear in what I really want to do. Waiting for your reply. Thanks and regards, Amol Quote:
December 13, 2015, 23:47 |
Lucky
Rep Power: 66 |
I don't remember if Fluent normally calculates the time-averaged volume fraction or not (maybe you can tell me, I am referring to the unsteady statistics option). If yes then you would still write the interpolate file the same way.
The only trick barrier is that Fluent treats the time-averaged and instantaneous variables at different named variables. So you would need to patch the instantaneous field with the time-averaged values. When patching zones Fluent doesn't let you reference the time-averaged quantities so you have to do a short workaround. Define a custom field function and set it equal to the time-averaged volume fraction. Then patch the instantaneous volume fraction with your custom field function. If Fluent doesn't give the time-averaged volume fraction, then you need to solve that problem first. Instead of an interpolate file, you can also write a profile. |
December 14, 2015, 23:28 |
Amol
Rep Power: 11 |
Hi LuckyTran,
Fluent writes RMS values of volume fraction when we activate the tab "data sampling for time statistics" under run activities. I could write the profile file of these RMS volume fraction of second phase. It gives me RMS values for different x and y co-ordinates. I will have to edit this profile file and add a third co-ordinate z and then will have to check if it works in 3D domain. But as far as I know, profile file works for patching of a face instead of domain. For interpolate option, I wrote .ip file from 2D simulation. However, when I tried to import in 3D, it shows the error of "interpolation file has wrong dimensions". I am not able to read and edit this .ip file so as to add the theird dimension. |
December 14, 2015, 23:53 |
#6 | |
Lucky
Rep Power: 66 |
The .ip file is a simple ascii text file. You can open and edit it with any text editor (but your file might require a lot of memory to open). The detailed formatting and structure of the file is available in the Fluent help. One of the first few lines in the .ip file is a 2 or 3 for 2D or 3D. Change it to 3 to see if you can read it as-is without adding the z-coordinate data. If you know how to do an fscanf or fprintf in any programming language then it shouldn't be too hard to edit the file yourself to add the z-coordinate since it's a plain text file. There are lots of other and easier ways as well. Such as defining a dummy field variable, exporting it, and then renaming this variable to become the z-coordinate. You're going to do 0th order interpolation anyway so the z-coordinate can be anything. But you have to understand the format of the .ip file for it to work. I haven't done a 3D profile either, I've always used a .ip file. I feel like it should work, but wouldn't beat myself up if I find out that it doesn't. |
December 23, 2015, 03:59 |
Amol
Rep Power: 11 |
Hi LuckyTran,
Sorry for the late reply. I read about the structure of the .ip file and could write a code to convert a 2D file into 3D. However, I need to test it before use it. Meanwhile, I also wrote a 2D profile file, edited it to add a third dimension and imported it in 3D case, but I could not get any profile in 3D case. Next thing I am gonna try out is to make a 3D case file with small z co-ordinate and then write a profile and interpolate file and import it in my actual 3D case to patch the volume fraction. Lets see if it works this way. Please post if you also have something to approach this problem. Thanks & regards, Amol |
May 25, 2016, 10:37 |
#8 | |
enass
Rep Power: 11 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Animation of Fluent transient data | saisanthoshm88 | CFX | 22 | August 14, 2017 19:06 |
Using FLUENT transient data in CFD-Post | GJC075 | FLUENT | 0 | November 25, 2013 09:56 |
transient simulation result file (.trn) ? | amine | CFX | 3 | June 14, 2008 05:01 |
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 | Mohammad Al-Shannag | Main CFD Forum | 1 | July 16, 1999 11:28 |
